come funziona un breaker magnetoidraulico?
giallok Offline
Registrato: Apr 2006 Online
Qualcuno conosce il funzionamento (o il principio) di un interruttore magneto idraulico, tipo airpax, e la differenza con un magnetotermico?
Fede55 Offline
Registrato: Sep 2012 Online
RE: come funziona un breaker magnetoidraulico?
Copiato pari pari da http://thegrid.rexel.com/topics/product_...plications
in pratica, in ambienti umidi o freddi, dove il normale interruttore termico potrebbe avere qualche problema di funzionamento anticipato o troppo veloce, gli viene aggiunto un "ammortizzatore" idraulico che rallenta leggermente la risposta al sovraccarico istantaneo...
Questo è quanto ho capito io! Smiley64
"Hydraulic-Magnetic Circuit Breakers
This type of circuit breaker is used whenever site conditions would interfere with the normal operation of thermal overload protection, including cases such as:
Low temperatures, which might prevent thermal protection from tripping.
High temperatures, which may trip thermal protection without an overload.
Environment moisture, which may absorb heat and affect the operation of thermal protection mechanisms.
Hydraulic-magnetic circuit breakers, whose overload protection is independent on temperature, offer a suitable solution for applications such as marine environments, transportation, generator rooms, and any industrial location with temperature or moisture extremes.
Hydraulic-Magnetic Circuit Breaker Operation
As mentioned before, thermal-magnetic circuit breakers accomplish their protection function through a combination of two elements: an expanding contact for overload protection and an induction coil for fault protection. Hydraulic-magnetic circuit breakers, on the other hand, accomplish both types of protection with an induction coil whose mechanical actuator is dampened by a fluid-filled cylinder.
If there is an overload, which only exceeds the rated current slightly, the induced magnetic field will be weak and the circuit breaker's trip will be delayed due to the dampened cylinder.
If there is a high-current fault, the induced magnetic field is very strong and the dampening effect is overcome instantly- providing an immediate trip."
Federico
31-01-2016 22:22
giallok Offline
Grazie Fede, utilissimo.
31-01-2016 22:41
pesce69 Offline
Registrato: Sep 2015 Online
Ciao, ma perchè allora il magneto idraulico costa molto meno rispetto al magnetotermico a pari caratteristica se ha una funzione in più?
13-04-2016 16:11
IanSolo Offline
Il magneto-termico ha un doppio dispositivo di intervento, uno magnetico ad intervento rapido (una bobina il cui campo magnetico attira l'ancoretta di sgancio) e uno termico (una lamina bimetallica che scaldandosi per il passaggio della corrente dopo un po' di tempo agisce anche lei sull'ancoretta di sgancio). Il magneto-idraulico ha un solo dispositivo di intervento di tipo magnetico e il ritardo e' ottenuto rallentando l'azione dell'ancoretta di sgancio mediante un liquido viscoso (da cuiil nome "idraulico") solitamente contenuto in un "pistoncino" ammortizzatore ma talora anche semplicemente steso sui perni o sulle guide di scorrimento, la sua costruzione puo' quindi risultare piu' semplice e meno costosa.
Entrambi hanno la proprieta' (per questo vengono usati) di non reagire subito a sollecitazioni di breve durata tipiche delle extracorrenti di spunto all'avviamento di motori, si sceglie uno o l'altro tipo secondo le caratteristiche del motore da proteggere e dell'ambiente in cui opera.
13-04-2016 17:14
pesce69 Offline
Risposta esauriente Smiley32 Per proteggere un salpa ancore da 500w può essere sufficiente quello idraulico? Ma poi ho guardato un po' i prezzi di quelli termici in continua per uso terrestre siamo a costi ben inferiori rispetto a quelli proposti dal settore nautico. Posso installarne uno in una scatola stagna con i sali per l'umidità?
14-04-2016 07:26
IanSolo Offline
Si puo' usare se le caratteristiche corrispondono:
- Per corrente Continua (quelli per solo alternata potrebbero non operare con gli stessi valori in CC)
- Con corrente di lavoro circa 1,5 volte (anche 2 volte) quella normale del motore a piena potenza (se non si conosce quella prescritta dal fornitore del motore)
- Con corrente di picco (istantanea) da 3 a 5 volte quella normale del motore a piena potenza (se non si conosce quella prescritta dal fornitore del motore)
- Tensione di lavoro adeguata (qui va fatto notare che i contatti per alta tensione sono di materiale diverso da quelli, piu' costosi, per bassa tensione in quanto la scintilla in chiusura che si genera in alta tensione perfora l'ossido eventualmente formatosi e di per se' effettua una "pulitura" del contatto migliorandone la funzione cosa che non accade a bassa tensione)
Il problema dell'umidita' non e' normalmente grave se l'interruttore e' in zona protetta dagli spruzzi e dalla nebbia salina, gli basta una comune scatoletta stagna da impianti elettrici se non sta all'interno della barca.
14-04-2016 08:47
pesce69 Offline
Thumbs Up RE: come funziona un breaker magnetoidraulico?
http://forum.amicidellavela.it/images/ic...umbsup.gif terrò in considerazione quanto hai detto, per fortuna ho tutte le caratteristiche del motore, ora basta che confronto i dati targa con le caratteristiche dei vari componenti.
Grazie per la consulenza 19
14-04-2016 11:37
  Webasto non funziona Nandox 2 506 13-08-2023 18:22
  AIS 250 non funziona Paolo Forti 14 3.489 10-10-2022 17:18
  Autopilota non funziona bene ggalizia 12 1.430 06-07-2022 20:12
  Breaker doppio, raddoppia la corrente? gava 7 1.043 15-02-2022 17:23
  tridata st60 non funziona log sventola 73 21.056 31-07-2021 10:56
  "Dubia" come funziona la corrente AC enio.rossi 27 3.885 08-10-2020 12:49
  AP ST6002 funzione che non funziona angelo2 4 1.198 24-09-2020 17:20
Thumbs Down Alternatore Valeo non funziona piu' BigLuc 18 16.542 17-08-2020 18:17
  cosa non funziona: pannello, regolatore, batteria? kpotassio 28 12.652 04-08-2020 09:26
  Raymarine splitter 100 non funziona Baluro 20 3.606 22-11-2019 15:49
