Stazza per il 2019 - IMS / ORC
cavallone Offline
Registrato: Mar 2005 Online
Information Stazza per il 2019 - IMS / ORC
Date: Tue, 08 Jan 2019 06:09:01 +0100
https ://orc.org /news /2019 /190107.htm
2019 ORC RULES, VPP AND CALENDAR OF EVENTS NOW AVAILABLE
Milan, Italy - The Offshore Racing Congress (ORC)
is pleased to announce the 2019 versions of its Rules and regulations, Velocity Prediction Program (VPP)
and Worldwide Calendar of events are now published and are available on the ORC website at www .orc .org
new 2019 CDL limits defining the three classes at ORC Championship events have been devised
for minimal disruption to the fleet from the 2018 limits, and are as follows:
Class A: 16.500 >= CDL > 11.620
Class B: 11.620 >= CDL > 9.800
Class C: 9.800 >= CDL > 8.600
The only change was small shift in the Class A-B split at 11.620 m CDL.
08-01-2019 11:51
cavallone Offline
Information RE: Stazza per il 2019 - IMS / ORC
per i pigri da tastiera, alcuni link diretti :
International Measurement System
IMS 2019
https ://orc .org /rules /IMS%202019 .pdf
ORC Rating Systems 2019
ORC International & ORC Club
https ://orc .org /rules /ORC%20Rating%20Systems%202019 .pdf
ORC Championship Rules
Standard Notice of Race
Standard Sailing Instructions
ORC Championship Checklist
2019
https ://orc .org /rules /Green%20Book%202019 .pdf
Summary of the changes to the ORC Rules and Regulations as approved at the
ORC Annual General Meeting held in Sarasota, USA on 31 October 2018
https ://orc .org /minutes /AGM%202018%20-%20Changes%20to%20the%20Rules .pdf
(Questo messaggio è stato modificato l'ultima volta il: 08-01-2019 12:45 da cavallone.)
08-01-2019 12:44
LiberaMente Offline
Registrato: Feb 2007 Online
Di solito viene fatto un file con il confronto su tutta la flotta tra i GPH dell'anno precedente e quelli nuovi.
Viene menzionato anche nell'annuncio.
Qualcuno lo ha o lo può trovare? io sul sito ORC non lo ho trovato
08-01-2019 13:17
cavallone Offline
(08-01-2019 13:17)LiberaMente Ha scritto:  un file con il confronto su tutta la flotta tra i GPH dell'anno precedente e quelli nuovi.
Ho visto solo la tranquillizzante (stai sereno...) chiaccherata a parole...
A test run shows that for 90% of the nearly 2000 designs in the ORCi fleet
the change in General Purpose Handicap (GPH) was only very small: +/- 0.5%.
This is within the normal scale of changes year to year as the system makes incremental progress in accuracy without causing disruptions to the fleet.
Moreover, a re-scoring of race results from the major 2018 ORC championships using the 2019 VPP showed little or no changes in scores.
"Yearly rating changes should not be cause for alarm," said Bruno Finzi, Chairman of ORC.
"Our process is to make the VPP better and more accurate every year through the substantial investment we make in research and development through the efforts of the ITC.
The very small changes for this year means that everyone should continue to enjoy the same close racing they have had with their prior use of the ORC system."
08-01-2019 14:43
davnol Offline
(08-01-2019 14:43)cavallone Ha scritto:  Ho visto solo la tranquillizzante (stai sereno...) chiaccherata a parole...
Vi ricordo che lo 0,5% di 600 sec/mg sono sempre 3 secondi....
Che non pare poco
D.
10-01-2019 19:52
shein Offline
(10-01-2019 19:52)davnol Ha scritto:  Vi ricordo che lo 0,5% di 600 sec/mg sono sempre 3 secondi....
Che non pare poco
che poi è il GPH, facile che sui coefficienti inshore/offshore il delta sia maggiore.
[b]Rock On Sail Fast!![/b]
11-01-2019 09:19
Chiodoni Offline
Registrato: Dec 2011 Online
Scusate ma entrando nel sito http://www.orc.org non ho capito da quale sessione si fanno le simulazioni di rating con le varie configurazioni qualcuno puo' spiegarmi ?
13-01-2019 11:56
Ercole67 Offline
Se ho ben capito la tua richiesta devi fare di volta in volta un certificato di prova, a pagamento. Carica il credito che vuoi, vai nella sezione "my boats", cerca la tua barca e da lì potrai fare le modifiche che vorrai.
13-01-2019 12:06
Chiodoni Offline
Ok grazie provero'
13-01-2019 13:01
cavallone Offline
Lightbulb RE: Stazza per il 2019 - IMS / ORC
(13-01-2019 11:56)Chiodoni Ha scritto:  entrando nel sito http://www.orc.org non ho capito da quale sessione
Ovviamente, devi essere entrato nella apposita sezione dedicata,
://data .orc .org /public /Wpub.dll
autenticandoti in alto a destra, con Username e Password...
giusto per chiarezza di esposizione
(Questo messaggio è stato modificato l'ultima volta il: 13-01-2019 14:21 da cavallone.)
13-01-2019 14:19
cavallone Offline
Questo pare che interessi a quelli che usano sia Spi Simmetrico che anche Asimmetrico
(se ho sbagiato mi corigerete)
114.4 If the asymmetric spinnaker is declared to be tacked at the TPS measurement only
as in 209.3(b), the VPP calculations will be taken accordingly
209.3 Spinnakers may be tacked:
b) when SPL is recorded in the certificate: on the spinnaker pole, except when declared that
an asymmetric spinnaker will be tacked at the TPS measurement point only
Certificates
Added a note when an asymmetric spinnaker is declared to be used tacked on the centerline only.
Submission: ARG 1 (October 2018)
ASYMMETRIC SPINNAKERS WITH OR WITHOUT POLE
PROPOSAL
When both symmetric and asymmetric spinnakers are in a sail configuration,
it should be possible to choose whether the use of the Asymmetric spinnaker is on a Pole.
RATIONALE
When there are both symmetric and asymmetric spinnakers in the sail configuration with SPL and TPS recorded,
a VPP run is done for all possible combinations, even if an asymmetric spinnaker is not necessarily used with a pole in all cases.
Therefore, it should be an option to declare if the asymmetric is used on pole in such configurations.
(Questo messaggio è stato modificato l'ultima volta il: 13-01-2019 18:26 da cavallone.)
13-01-2019 18:25
nedo Offline
Essendo madrelingua bergamasca con l'inglese c'azzecco poco, bisogna specificare forse dove viene murato il gennaker , ovvero oltre alla misura indicata dal TPS se vi sono altre posizioni intermedie sul bompresso ? !! Smiley57
Seneca
14-01-2019 10:54
cavallone Offline
Shocked RE: Stazza per il 2019 - IMS / ORC
(14-01-2019 10:54)nedo Ha scritto:  Essendo madrelingua ...
Eh.. siamo tutti madrelingua (la nostra...) così come siamo tutti Residenti (a casa nostra..)100
Credo si riferisca,
non tanto a varie posizioni intermedie sul medesimo bompresso,
ma piuttosto, invece,
a chi mura l'Asimmetirco sul tangone, e quindi lo può "quadrare" angolandolo sopravvento, come fa quando usa lo Spi Simmetrico.
(è una manovra un pochino complessa, specialmente nelle strambate, ma qualche equipaggio allenato lo fa).
Adesso dal 2019 mi par di capire che nel calcolo dal Rating,
venga peggiorato quello che usa tale possibilità,
mentre viene favorito quello che si accontenta di murare l'Asimmetrico soltanto sul bompresso lungo la mezzeria dello scafo.
_se sbagio mi corigerete_
s.e.&o.
14-01-2019 12:39
Chiodoni Offline
Mi sembra che tra le barche iscritte gia' al mondiale orc di sebenicco ce ne stanno alcune in classe C con cdl maggiore di 9,8 ad esempio un paio di mumm con 9,82 e 9,89 , perche'?
26-01-2019 20:02
albert Offline
(26-01-2019 20:02)Chiodoni Ha scritto:  Mi sembra che tra le barche iscritte gia' al mondiale orc di sebenicco ce ne stanno alcune in classe C con cdl maggiore di 9,8 ad esempio un paio di mumm con 9,82 e 9,89 , perche'?
Questo è tratto dal bando.
4.3. Classes are defined by the CDL and the minimum and maximum number of entries as follows:
Class A: 16.500 >= CDL > 11.620 max. 50 entries (30 from one country)
Class B: 11.620 >= CDL > 9.800 max. 50 entries (30 from one country)
Class C: 9.800 >= CDL > 8.600 max. 50 entries (30 from one country)
Note: All CDL values are referred to 2018 version of the ORC VPP and it may be updated when the 2019 VPP becomes available
Presumibilmente i cdl nella entry list sono ancora riferiti al vpp 2018 e ritengo che gli armatori abbiano dichiarato che verranno comunque “riaggiustati” con il rinnovo del certificato 2019, necessario per formalizzare l’iscrizione (e con le nuove vele ).
Dato che i numeri degli iscritti sono chiusi, il passaggio da una classe all’altra non è detto che sarà poi possibile, dunque l’organizzazione nelle preiscrizioni accetta le dichiarazioni di “intenti”.
(Questo messaggio è stato modificato l'ultima volta il: 26-01-2019 22:41 da albert.)
26-01-2019 22:40
cavallone Offline
(26-01-2019 20:02)Chiodoni Ha scritto:  alcune in classe C con cdl maggiore di 9,8
Guardandoci adesso per Orc C,
il numero CDL più grande mi parrebbe 9,78 per un G.S.37
s.e&o.
nedo Offline
Permettetemi una domanda innocente :
una barca con CDL inferiore a 8.600 può partecipare al mondiale o no, se si a quale classe verrebbe assegnata !? Smiley57
Grazie Smiley2
Seneca
28-01-2019 14:50
globulo rosso Offline
No non può partecipare. È una cosa vergognosa, più volte ho sottoposto la questione all'uvai senza alcun interessamento. È una questione di disparità davvero brutta nata con l'ingresso delle CDL, infatti prima si poteva ed io nel 2013 corsi il mondiale ad Ancona.
...Gli armatori di queste barche pagano i certificati ugualmente ad altri...Ci sono barche italiane in classe 4 forti, veloci e curate come le barche top...eppure. Hai il 31 piedi?sei un poveraccio...La vela è roba da ricchi!
29-01-2019 07:12
Il problema sorge anche con l'Europeo ORC, stesso taglio e stessa "distrazione" sui classe 4. Vedi se in IRC funziona cosi'! A marsiglia durante l'Europeo IRC il gruppo dei 31 piedi era il più numeroso: barche forti e velisti di caratura olimpica su quasi tutti gli scafi. Poi dici perché i francesi sono avanti...
29-01-2019 07:17
nedo Offline
(29-01-2019 07:12)globulo rosso Ha scritto:  No non può partecipare. È una cosa vergognosa, più volte ho sottoposto la questione all'uvai senza alcun interessamento. È una questione di disparità davvero brutta nata con l'ingresso delle CDL, infatti prima si poteva ed io nel 2013 corsi il mondiale ad Ancona.
Grazie della risposta, conferma quanto mi era stato segnalato da amici, conosco infatti situazioni di barche al top con CDL al limite e armatori che si dannano e pagano più volte lo stazzatore al fine di trovare una configurazione tale da garantirgli l'accesso alla classe !
La CDL essendo vincolata alla IMSL e alla vmg con 12 kn risulta già problematica per molti 34' 37
Seneca
29-01-2019 10:43
  Doppio segno di stazza ghibli4 5 963 13-06-2022 14:27
  stazza della randa capatosta 6 1.246 21-12-2021 13:01
  Come ottenere Certificato di stazza e quale categoria scegliere per Salona 45 lelez86 23 3.995 14-12-2021 18:15
Information Stazza per il 2020 - IMS / ORC cavallone 3 1.609 08-05-2020 18:09
  il code0 cambia misure di stazza ZK 49 6.414 06-02-2020 22:20
Lightbulb Stazza per il 2020 IRC cavallone 4 1.395 08-01-2020 22:19
  Certificato di Stazza e ORC andre082 3 2.545 14-10-2019 16:12
Lightbulb Normativa Altura 2019 cavallone 1 1.207 30-01-2019 23:44
Exclamation Regate in Gennaio 2019 - validità delle Tessere Fiv cavallone 5 1.656 06-01-2019 14:45
  OSR Offshore Special Regulations 2018 – 2019 cavallone 0 2.240 17-01-2018 00:43
