Posizione invertitore con autoprop a vela
infinity Offline
Registrato: Aug 2010 Online
RE: Posizione invertitore con autoprop a vela
Hai ragione Kermit, semplice ed efficace... eccolo
Ref No.: YMTQTB11-017
Date: October 18, 2011
Page 1 of 2 GTB2010005
To : Yanmar Marine Regional Head Quarters and
All Yanmar marine distributors
Subjects : Yanmar Sailboat engine control lever position during sailing
under sail with engine stopped
1. Introduction
Yanmar wishes to inform you about the instruction of the control lever position during sailing under
sail with engine operation stopped. This instruction is subjected to mechanical type gearboxes and
sail drives only.
2. Operation instruction
2-1 Mechanical Cone clutch :
Applicable models: Sail Drive: Models SD 40, SD50 and SD50-4T
Marine gear: Models KM2P, KM35P, KM35A and KM4A
When mechanical cone clutch type gearbox or sail drive is equipped with the following propeller:
a. Fixed propeller:
When sailing under sail with engine operation stopped put control lever into Neutral. The output shaft keeps rotating.
Notice:
When control lever is put in Reverse position, cone slippage will be introduced and void your warranty and there is possibility that the clutch doesn't disengage. This can be a problem for
engine re-starting.
There are options to stop free rotation of propeller-shaft if customer doesn’t want occur noise from rotating propeller:
1) For sail drive: install folding propeller or Feathering propeller instead of fixed propeller.
2) For marine gear: install the Shaft - Lock device, Yanmar does not supply, on the propeller shaft.
b. Folding propeller: (including GORI Over-drive propeller)
When sailing under sail with engine operation stopped put control lever into Reverse position, this to operate the folding propeller to fold close blade and output-shaft stops from rotating.
After this operation put the control lever back into Neutral.
c. Feathering propeller:
When sailing under sail with engine operation stopped put control lever into Reverse position, this to operate the feathering propeller into feathering position and output-shaft stops from rotating. After this operation put the control lever back into Neutral.
2-2 Other Mechanical clutch:
Applicable model: Sail Drive: Model SD20, SD31 (Dog clutch type)
Marine gear: Model KBW10, KBW20, KBW21
(Mechanical single or multi disc clutch) When mechanical dog clutch or mechanical disc clutch is equipped with the following propeller:
a. Fixed propeller:
When sailing under sail with motor stopped put control lever into Neutral. The output shaft keeps rotating.
Notice:
When control lever is put in Reverse position there is a possibility the clutch does not disengage.
This can be a problem for engine re-starting.
There are Options to stop free rotation on propeller shaft if customer doesn’t want occur noise by rotating:
2) For marine gear: install the Shaft-Lock device, Yanmar does not supply, on the propeller shaft
When sailing under sail with engine stopped put control lever into reverse position, this enables the folding propeller to fold close blade and output-shaft stops from rotating. After this operation put the control lever back into neutral or remain reverse position as you like.
When sailing under sail with engine stopped put control lever into reverse position, this enables the feathering propeller into feathering position and output-shaft stops from rotating. After this operation put the control lever back into neutral or remain reverse position as you like.
Notice:
Do above mentioned operations with a boat speed <3knts when sailing under sail with engine operation stopped.
04-07-2017 12:43
N/A Offline
È consigliato spegnere a marcia inserita perché l'elica potrebbe continuare a girare mettendo a folle, per una serie di concause che credo siano ovvie e dovute sia alla velocità del fluido e sia alla forma delle pale.
Inoltre, inserire la retro mentre l'invertitore ed asse stanno girando potrebbe causare danni
14-07-2017 20:44
N/A Offline
Messaggio: #43
Ieri incuriosito ho fatto delle prove e sono rimasto incredulo: credevo che con marcia inserita l'invertitore restasse bloccato ed invece no. Con ewol se spengo il motore con marcia inserita si ferma subito a bandiera ma se provo a girare l'elica, essa è libera di muoversi. Se invece, con motore spento, inserisco la retro, l'asse si blocca in un verso e nell'altro continua a girare
16-07-2017 09:53
raffasqualo Offline
Registrato: Feb 2012 Online
Messaggio: #44
sono incuriosito da quanto affermato da TestaCuore.
Come è possibile ciò. Qual'è il modo corretto?
Una mia idea, prima di riavviare bisogna mettere in folle prima, io faccio sempre così.
16-07-2017 10:05
N/A Offline
Messaggio: #45
Preciso che la prova l'ho fatta stando fermo all'ancora
16-07-2017 12:11
Itablu Offline
Messaggio: #46
Buonasera a tutti una domanda con autoprop Montata su un volvo d2 75 mi hanno consigliato sia di spegnere lil motore con marcia inserita in avanti e lasciarl durante la navigazione a vela che di riaccenderlo in caso di navigazione a vela sempre con marcia inserita in avanti. Cosa ne pensate
27-12-2023 01:54
infinity Offline
Messaggio: #47
(27-12-2023 01:54)Itablu Ha scritto:  Buonasera a tutti una domanda con autoprop Montata su un volvo d2 75 mi hanno consigliato sia di spegnere lil motore con marcia inserita in avanti e lasciarl durante la navigazione a vela che di riaccenderlo in caso di navigazione a vela sempre con marcia inserita in avanti. Cosa ne pensate
ne penso che devi chiedere a Volvo Penta, quello che o ho sopra-riportato vale per Yanmar che ha emanato il Technical Bulletin che ho riportato.
per Volvo non lo so e non voglio correre il rischio di darti un consiglio sbagliato
27-12-2023 18:10
velaciak Offline
Messaggio: #48
Io sono costretto a mettere in moto con marcia inserita in quanto dopo veleggiata con marcia avanti inserita il folle non entra.(YANMAR 3YM30 AUTOPROP 3 pale)
27-12-2023 18:23
infinity Offline
Messaggio: #49
(27-12-2023 18:23)velaciak Ha scritto:  Io sono costretto a mettere in moto con marcia inserita in quanto dopo veleggiata con marcia avanti inserita il folle non entra.(YANMAR 3YM30 AUTOPROP 3 pale)
e ti va già bene che non spacchi i coni frizione!!
come vedi dal technical bullettin riportato da me sopra, YANMAR chiede venga lasciato in folle:
(Questo messaggio è stato modificato l'ultima volta il: 27-12-2023 18:45 da infinity.)
27-12-2023 18:44
velaciak Offline
Messaggio: #50
(27-12-2023 18:44)infinity Ha scritto:  e ti va già bene che non spacchi i coni frizione!!
Stefano Cova Che vende le Autoprop ha sempre detto che a vela va inserita la marcia avanti.
28-12-2023 01:22
Canadese Offline
Messaggio: #51
Anch'io stesso motore, stessa Elica, stesso problema
28-12-2023 02:09
infinity Offline
Messaggio: #52
(28-12-2023 01:22)velaciak Ha scritto:  Stefano Cova Che vende le Autoprop ha sempre detto che a vela va inserita la marcia avanti.
Stefano Cova è stato messo al corrente della direttiva Yanmar ed adesso non dice piu cosi.
permale la marcia avanti solo in alcuni casi riportati qui:
1. Introduction
sail drives only.
a. Fixed propeller:
Notice:
engine re-starting.
a. Fixed propeller:
Notice:
Notice:
se nonci credi chiedi a Yanmar EU.... (l'importatore Italiano non capisce una XXXXX)
28-12-2023 14:18
Canadese Offline
Messaggio: #53
Grazie Infinity, proverò a innestare la retro e poi mettere in folle come da istruzioni Yanmar. In effetti rimettere in moto con la marcia innestata perchè non rientrava la folle non mi è mai piaciuto. Speriamo funzioni...
28-12-2023 16:13
velaciak Offline
Messaggio: #54
Se ricordo bene, nelle andature a vela, con la retro inestata l'asse gira trascinato dall'eica autoprop.
28-12-2023 17:39
bullo Offline
Messaggio: #55
Per bloccare l'elica si mette la marcia indietro. Per metterlo in moto in folle.
Con tutti i motori,tutti con elica destrorsa fuorchè il volvo sinistrorso.-
28-12-2023 18:33
GARIBALDI Offline
Messaggio: #56
(28-12-2023 18:33)bullo Ha scritto:  Per bloccare l'elica si mette la marcia indietro. Per metterlo in moto in folle.
Motore Bukh 36 sinistrorsa elica j.prop messa sempre retro per andare a vela.
28-12-2023 22:28
  INVERTITORE ZF HBW35 - problemi in marcia avanti Goriboy 4 231 06-05-2024 15:08
  quale è il tappo da svitare per rabboccare l'olio dell'invertitore ? faber 25 2.675 25-04-2024 17:27
  Yanmar 4JH3E gioco cavo comando invertitore enricomarzico 10 512 14-04-2024 23:24
  Elica Autoprop 3 pale Sundurighi 140 45.281 06-04-2024 19:32
  Yanmar - invertitore SD50 - astina olio elan 333 3 772 03-04-2024 18:11
  Invertitore che perde olio - Aggiornamento palve 24 11.881 16-01-2024 00:12
  Rumore invertitore / giunto parastrappi silvio 21 1.998 04-01-2024 23:20
  invertitore TMC40 bloccato vonkapp 5 484 24-12-2023 20:01
  Leva comando acceleratore ed invertitore Fabino 9 742 06-12-2023 23:56
  olio dell'invertitore: cambiarlo tutti gli anni? augustob 34 9.472 08-10-2023 12:41
