vele di prua
francocr68 Offline
Registrato: Nov 2007 Online
vele di prua
regata ORC:
è permesso fare questo???
Teoricamente si, sta usando una sola vela infierita, l'altra è libera
Foto prese dal sito di Marci, scattate alle regate di Capitana domenica scorsa
25-02-2014 15:54
albert Offline
Registrato: Jun 2008 Online
vele di prua
Che fai ? Domandi e ti rispondi nello stesso post ?WinkWink
Regolamento ORC:
207 Headsails
207.1 Headsails, except an inner headsail set flying shall be tacked approximately on a boat's centerline.
207.2 Two headsails may be set on the same tack point, only if no spinnaker is in use (This amends RRS 50.1).
207.3 If the headsail is set flying, no tack pennant greater than 0.762 m may be used.
207.4 When a headsail is tacked inside spinnaker or inside another headsail, if it is trimmed flat along the
center line of the boat:
a) the clew shall not be aft of the clew of the foremost headsail trimmed on the same way
b) no more than 50 per cent of its area shall fall abaft the foreside of the mast.
207.5 No headsail shall be set flying and tacked in front of the forestay when any spinnaker is set.
207.6 Headsails may be sheeted:
a) to any part of the deck or rail
b) to a fixed point no higher than 0.05*MB above the deck or coach roof
c) to the main boom within the measurement limit according to IMS F5.3.
d) to the spinnaker pole in accordance with RRS 50.2 and 50.3©.
Headsails shall not be sheeted to any other spar or outrigger.
REGOLAMENTO REGATA ISAF 2013-2016:
50 SETTING AND SHEETING SAILS
50.1 Changing Sails
When headsails or spinnakers are being changed, a replacing sail
may be fully set and trimmed before the replaced sail is lowered.
However, only one mainsail and, except when changing, only one
spinnaker shall be carried set at a time.
50.2 Spinnaker Poles; Whisker Poles
Only one spinnaker pole or whisker pole shall be used at a time
except when gybing. When in use, it shall be attached to the foremost
mast.
50.3 Use of Outriggers
(a) No sail shall be sheeted over or through an outrigger, except as
permitted in rule 50.3(b) or 50.3©. An outrigger is any fitting
or other device so placed that it could exert outward pressure
on a sheet or sail at a point from which, with the boat upright, a
vertical line would fall outside the hull or deck. For the purpose
of this rule, bulwarks, rails and rubbing strakes are not part of
the hull or deck and the following are not outriggers: a
bowsprit used to secure the tack of a sail, a bumkin used to
sheet the boom of a sail, or a boom of a boomed headsail that
requires no adjustment when tacking.
(b) Any sail may be sheeted to or led above a boom that is
regularly used for a sail and is permanently attached to the
mast from which the head of the sail is set.
© A headsail may be sheeted or attached at its clew to a spinnaker pole or whisker pole, provided that a spinnaker is not set.
Mi sembra che le regole che si possono verificare da foto siano state tutte rispettate.....e come si legge, non sembra discriminante che il secondo genoa sia 'set flying' o inferito.
25-02-2014 16:32
ghibli4 Offline
Registrato: Aug 2007 Online
vele di prua
Notare l'espressione del prodiere con giacca rossa nella terza foto. Tipica di chi l'ha fatta ed aspetta il risultato dell'azione.
25-02-2014 17:16
anonimone Offline
Registrato: Jan 2007 Online
vele di prua
ho qualche dubbio sui vantaggi reali in un bastone medio/corto (anche medio/lungo a dire il vero).
C'è un qualche vantaggio di compenso dichiarando l'uso del tangone ma non dello spi?
ZK Offline
Registrato: Dec 2005 Online
vele di prua
il vantaggio e' abbastanza in linea col peggioramento del numerello.
e' una cosa buffa, il 90%dei velisti si preoccupa di tenere su la randa per equilibrare la barca di bolina.. che e' una fesseria, e non si preoccupa di equilibrare il piano velico di poppa, cosa che rende un botto.
ammainare un genova o un fiocco non inferito... non e' una cosa banale.. tocca sapere come fare.Smiley14
25-02-2014 20:57
albert Offline
vele di prua
Maaa....dato che non si vedono spi all'orizzonte e non mi sembra che le condizioni siano così proibitive, non è che, nonostante le vele siano nereWink, le foto siano di una flotta che sta regatando in categoria 'vele bianche' ??
In quel caso si dovrebbe vedere cosa ch'è scritto nel bando, se è specificato cosa si può issare e come o se è richiamata la normativa per l'altura:
Il termine “a vele bianche” significa imbarcazione che naviga esclusivamente con randa e fiocco (e fiocco è singolare Wink)
26-02-2014 00:28
francocr68 Offline
vele di prua
le condizioni non impedivano l'uso dello spi, il resto della flotta infatti lo ha issato tranquillamente.
Normalmente quella barca issa spi in poppa, qualche volta 2 (squalificata), qualche volta è arrivata in regata senza motore
(il timoniere dichiarò che si era dimenticato che era stato sbarcato). Questa volta forse non avevano uno spi (o lo avevano già rotto), fatto sta che questa barca ed il suo timoniere 'centenario' nelle ns acque sono ben conosciuti e temuti.
26-02-2014 00:49
Brunoc Offline
Registrato: Jul 2007 Online
vele di prua
come dice Franco, l'amico è molto conosciuto a Cagliari.
Domenica non l'hanno messo in classifica benchè arrivato, non so se perchè ha toccato le boe o che non ha pagato le quote di iscrizioneSmile... però riesce sempre a stupire!
bv
26-02-2014 01:41
Mister Joy Offline
Registrato: Jun 2013 Online
vele di prua
scusa l'ignoranza ma mi spieghi meglio il concetto 'equilibrare il piano velico in poppa al fine di una migliore resa?'
18-03-2014 17:46
tiger86 Offline
vele di prua
Nel senso che anche di poppa la barca va equilibrata a piacimento e a seconda delle situazioni meteo-marine.
La randa entra certamente in gioco in questo equilibrio.
Condivido anche con ZK la smorfia su quel virus diffuso che ritiene una barca di bolina con solo Genoa per forza con tendenza poggiera Disapprovazione
Leandro
18-03-2014 22:03
mantonel Offline
Registrato: Jun 2005 Online
vele di prua
So che non e' piu' di moda, ma a me quell'armo piace. E non solo perche piaceva a Sciarrelli!
22-03-2014 01:51
ZK Offline
vele di prua
non e' uno show 29 armato in testa?
e che c'entra con sciarrelli?
22-03-2014 05:59
  prendere giri allo strallo di prua con avvolgifiocco bamar c0t ismael 12 992 20-08-2023 15:34
  Vela di prua per piatte cmv88 10 1.246 28-07-2023 13:03
  Problema con Fiocco e battagliola di prua Vittorio Camino 15 1.369 26-07-2023 11:29
Star Strallo di prua sbatte al vento Anna123456789 12 2.151 19-05-2022 19:29
  Estruso Strallo Prua Alfredo56 2 1.147 19-12-2021 13:27
  Nomenclatura vele di prua France WLF Sailing Team 26 4.021 07-11-2021 20:53
  Strallo prua avvolgifiocco moooolto lento...sfilacciato? Rigger tirreno? gava 7 1.639 24-06-2021 21:34
  Vele di prua avvolgibili senza cavo antitorsione timeout 56 10.189 16-12-2020 00:59
  Percentuale di sovrapposizione vela di prua seromanzi 2 1.512 23-11-2020 19:43
  First 20, terzaroli e vela di prua kobold 44 5.673 27-10-2020 11:29
