Albero Selden con rollaranda
Sgt.Pepper Offline
Qualcuno magnanimamente mi dice quale è la manutenzione annuale da fare a questo impianto, del quale per altro sono soddisfattissimo SmileSmileSmile
grazie e un saluto
Cosa sono le leggi senza i costumi.
02-10-2011 16:03
mantonel Offline
Registrato: Jun 2005 Online
nulla.
03-10-2011 15:00
Madinina II Offline
Registrato: Dec 2006 Online
Citazione:mantonel ha scritto:
nulla.
Geniale !!! Big Grin
03-10-2011 16:26
sailor13 Offline
Citazione:Maintenance should be undertaken at least once a year all bearings should be greased with grease (Part no. 312-501), a tube of which is delivered with the mast. Read the following instructions and fig. 9:1.
Halyard swivel
Grease the bearings by pressing grease directly into the recesses #61569; and #61570; by the rotating ring. This is Best done when the swivel is opposite the sail feed inspection hole #61575;.
Seldén furling mast gear.
Remove the upper oval plastic plug #61572;.
Lift the rubber boot, and grease the upper bearing #61571; on the roller mechanism.
Remove the lower oval plastic plug level with the reefing winch and on the side of the mast. Grease the bevel gears #61573;, and the ball bearing #61574;.
All grease points are shown in fig. 9:1.
Maintenance of the Seldén
furling mast
Periodic maintenance
If the reefing system should begin to be stiff after several years usage it can be necessary to dismantle its components for servicing. Clean the gears and ball-bearings from old grease and relubricate.
The seldén furling mast is designed for easy servicing even after a long period of time. The holding
Bolts for the reefing unit are screwed into stainless steel blind nuts and are not subject to corrosion.
Dismantling is described on page 12.
03-10-2011 16:35
cody Offline
Registrato: Feb 2007 Online
Exclamation Albero Selden con rollaranda
per noi 'gnurant curiosiBig Grin
google traduttore:
La manutenzione deve essere effettuata almeno una volta all'anno tutti i cuscinetti devono essere lubrificati con grasso (parte no. 312-501), un tubo di cui viene fornito con l'albero. Leggere le seguenti istruzioni e fig. 9:1.
testa girevole
Ingrassare i cuscinetti di grasso premendo direttamente nei recessi # 61569 e # 61570; dalla ghiera girevole. Questo è fatto meglio quando la rotazione è di fronte al foro di ispezione vela feed # 61575;.
Seldén avvolgifiocco albero del cambio.
Togliere il tappo superiore di plastica ovale # 61572;.
Sollevare lo stivale in gomma, grasso e il cuscinetto superiore # 61571; sul meccanismo a rullo.
Rimuovere abbassare il livello di forma ovale tappo di plastica con il verricello reefing e sul lato del palo. Ingrassare gli ingranaggi della smussatura # 61573, e il cuscinetto a sfera # 61574;.
Tutti i punti di grasso sono mostrati in fig. 9:1.
Manutenzione del Seldén
manutenzione periodica
Se il sistema reefing dovrebbe cominciare a essere rigido, dopo diversi anni di utilizzo può essere necessario smontare i suoi componenti per la manutenzione. Pulire gli ingranaggi e cuscinetti di grasso vecchio e lubrificarla.
L'albero Seldén avvolgibile è stata progettata per una facile manutenzione anche dopo un lungo periodo di tempo. l'azienda
Bulloni per l'unità reefing sono avvitati dadi in acciaio inox cieco e non sono soggetti a corrosione.
Lo smontaggio è descritta a pagina 12.
Halyard swivel
furling mast
03-10-2011 21:08
Sgt.Pepper Offline
GrassssieBig GrinBig GrinBig Grin
03-10-2011 21:39
sailor13 Offline
comunque i manuali originali li trovi [url='http://www.seldenmast.com/frameset.cfm?id=6611&randnum=324948265']qui[/url]
04-10-2011 00:15
  Dubbio rollaranda santicuti 10 1.203 04-01-2024 14:15
  SELDEN - carrelli MDS albero maras 3 654 02-11-2023 19:15
  Albero con rollaranda che sbatacchia ventodiprua 7 1.211 05-09-2022 15:17
  Smontaggio campana del whinch rollaranda Selden zerbaglia 0 649 13-06-2022 13:43
  Vang Selden Rodkicker (591-300) ita2282 9 9.400 03-02-2022 16:32
  Rottura rollaranda ZSpars (aggiornamento) pacman 30 7.328 02-04-2021 09:50
  riutilizzare albero passante come albero appoggiato Sikander 9 2.642 24-03-2021 03:37
  Quale vela per rollaranda? ventodiprua 13 2.241 17-11-2020 21:38
  Costo albero Selden Bavaria 40 per informazione assicurazione kavokcinque 4 2.296 17-11-2020 13:48
  Terza mano su boma Selden a 2 mani borosa unica kavokcinque 14 3.069 20-04-2020 07:08
