Il code 0 và dichiarato in IRC-non è uno spy
sventola Offline
Ho appena finito una regata lunga con vento tra i 3 e 6 nodi e mi è capitato di constatare che almeno un concorrente usava con molta disinvoltura un Code 0. Ho controllato il suo rating (610 circa per un first 40,7) ed escludo che l'abbia dichiarato. Leggo poi alcuni post in cui si sostiene che tale vela non essendo infierita sia uno spy/genny. Questo è assolutamente non corripondente al vero e riporto uno scritto che spiega perchè:
There are quite a few misconceptions as to what an IRC code zero sail is and at what angles it can be used.
An IRC code zero is measured as a spinnaker, so it must have a mid-girth measure- ment that is at least 75 percent of the foot length and a leech length that is no more than 95 percent of the luff length.
Volvo 70s are often seen sailing upwind with what many people call a code zero. However, these upwind sails have mid-girth measure- ments that are 55 to 65 percent of the foot length. Because these sails don’t have to support all this extra area, they can be designed flatter and used at tighter angles.
A typical IRC code zero needs a lot of additional shape in order to support the large mid girth.
These sails are difficult to design; you want to build in just enough depth to support the girth and prevent the leech from flapping while still getting the sail as flat as possible so it can be carried at a tight angle. If done right, how- ever, a code zero can be quite advantageous for boats with non- overlapping jibs in point-to-point races. But don’t think for one moment that it will sail upwind; 90 degrees true wind angle is as high as they’ll go.
The Technical Stuff:
IRC definitions define a spinnaker as
Spinnaker: RRS 50.4 shall not apply. A spinnaker is defined as a sail set forward of the foremost mast with half width (measured as a spinnaker) equal to or greater than 75% of foot length and without battens.
Thus, if a sail satisfies the definition of a spinnaker (ie half width is equal to or greater than 75% of foot), then that is what it is: a spinnaker. Any other sail is a headsail. ‘Code zeros’ are nearly always intended by the sailmaker to be spinnakers. Measurers should however beware. If however a sail has battens, defined in IRC as Any material added to the sail, as either a removable element, permanent stiffening, or other contrivance, the purpose of which is to support and/or stiffen the sail. then it is a headsail rather than a spinnaker, irrespective of what the dimensions are'
La prox volta per dovere di chiarezza riporterò foto e nome barca.CoolCoolCoolCool
(Questo messaggio è stato modificato l'ultima volta il: 06-07-2012 18:31 da sventola.)
06-07-2012 17:17
davnol Offline
per poterlo infamare.....devi sincerarti che la midgirt non sia effettivamente superiore al 75%
e' abbastanza facile, vedi foto di code 0 sui vari siti....
fatto questo ed essendo sicuri della violazione, un paio di foto ducumentano il tutto.
da di li le strade si aprono....
d.
06-07-2012 18:54
kermit Offline
Registrato: Sep 2006 Online
Max secondo me stai toccando un argomento che scotta...parecchio, se non sei stato danneggiato direttamente in regata ti consiglio di lasciar perdere.
I regolamenti sono fatti a volte anche per essere aggirati ed una protesta di stazza per come posso immaginare io (con le foto) farebbe un flop.
L'argomento Code 0 nel regolamento IRC credo sia opportunamente tenuto sottobanco apposta, non ti nascondo che io lo volevo fare ma il mio Velaio me lo ha sconsigliato.
06-07-2012 19:02
albert Offline
Non c'è nessun mistero o lato oscuro.
Il code 0 se la larghezza mediana è inferiore al 75% della base va stazzato come headsail, ovvero come Genoa e la j viene considerata la distanza da dove viene murato alla faccia anteriore dell'albero.
Se non è così si fa una protesta, la foto serve solo per individuare la vela e dove era murata. Le misure le prende poi lo stazzatore dal vero.
06-07-2012 19:59
davnol Offline
Semplice....chiaro....lineare.....albert
Big Grin
D.
06-07-2012 20:48
sailyard Offline
Registrato: Apr 2010 Online
Big Grin
D.
Mi piace !
06-07-2012 22:03
kermit Offline
Si tutto condivisibile ma a una settimana dalla fine della regata che protesta fai?
07-07-2012 04:55
Powerspi Offline
I Code 0 si fanno anche conforme al regolamento IRC.
Avendo una barca stazzata con genoa senza sovraposizione per le lunghe può fare senso.
Se hai una foto si vede facilmente se è conforme.
07-07-2012 05:20
albert Offline
E'ovvio che la protesta vada fatta nei tempi stabiliti dalle idr per le proteste.....ovvero è ovvio che i suggerimenti fossero 'per la prossima volta'....Wink
07-07-2012 06:19
albert Offline
Tanto per chiarire ripetiamo: per essere stazzata come spinnaker una vela di prua deve avere la larghezza mediana maggiore del 75% della base: se ha queste caratteristiche però è un A zero e non un code zero....
Se la larghezza è inferiore è un code zero, ma in IRC va stazzato come headsail.
Se mi è sfuggita qualche regola, ti prego di segnalarmelo....
Sono anche curioso di capire come si riescano a misurare le larghezze di uno spinnaker asimmetrico su una fotografia panoramica ...Wink
(Questo messaggio è stato modificato l'ultima volta il: 07-07-2012 06:44 da albert.)
07-07-2012 06:24
Powerspi Offline
Il regolamento è quello citato da sventola o meglio quello che si raggira.
E' una forzatura utilizzando la midgirth di 75% con strallo dritto o quasi.
Il risultato è una vela con balumina a forte 'allunamento' positivo.
Mi pare che sia nato proprio cosi poi l'ORC ha tolto questa forzatura accettando
55%.
07-07-2012 06:44
Powerspi Offline
Ho scritto prima della tua modificaWink
E' questione di definizioni. Quello che definisci A0 in paesi anglosassoni
viene chimato C0 (vedi anche sito NS americano)
Distinguere tra un C0 tipo ORC/55 con un 75 non è cosi difficile..
07-07-2012 06:52
albert Offline
Se la vela, anche se stortignaccola, ha la larghezza mediana > del 75% della base, si chiama A zero......e va comunque come un A zero, perchè è ben difficile che una vela piatta possa avere il 25% di allunamento positivo in balumina senza flappeggiare vistosamente....
...ora vado a nanna....ciao
07-07-2012 06:54
  genoa leggero usato come code zero Wally 2 171 27-05-2024 13:20
Question Code 0: le misure per Dufour 360 ? gr8wings 4 895 17-04-2023 17:09
  Code 0, consiglio su diversi preventivi. davidevet 65 18.597 08-04-2023 14:11
  Code zero come armarlo sull'albero ecotango 84 12.907 25-01-2023 13:09
  Drizza 2:1 per code-0 su armo in testa d'albero Chimera 37 8.216 24-10-2022 18:30
  Code 0 senza frullone ottavio56 15 2.453 24-10-2022 10:15
  Code-0 e frullone (rollgen) windex 34 4.019 19-07-2022 10:17
  code 0 jomabrasil 6 1.581 18-11-2021 10:24
  Code zero, vela difficile? rosella1970 22 3.709 23-10-2021 12:30
  Genoa 140 o 105 e code mzambo 32 7.040 08-10-2021 10:54
