girella dell'ancora
Madinina II Offline
Registrato: Dec 2006 Online
girella dell'ancora
Spulciavo qua e là e leggo queste note nel sito della Rocna, e visto che lo trovo interessante ve lo copio:
Recommended swivel types
If you do use a swivel, use one of a reputable brand. This mostly precludes generic brands and anything of questionable origin. Galvanized swivels are easily available, cheaper than stainless, but are more 'agricultural'. They tend to bind when new, then rust at the joint as the galvanizing wears. Stainless swivels are expensive, and you get what you pay for. The budget must be a lot higher than for shackles to obtain equivalent quality and security.
The failure mode of swivels is typically when they are subjected to lateral forces. This means it is ideal to install the swivel in such a way that lateral forces cannot be applied across the joint. One way to do this is to use a reputable inline type with a few links of chain between the anchor and the swivel. Generally, installing the swivel directly on the anchor shank is not a great idea.
Ball-and-joint types go some way toward mitigating this issue, but an articulation of only the typical 30 degrees is barely adequate. The safe-working-loads on these swivels is normally not calculated with a force applied outside of this operating range, which is unrealistic.
Quindi confermano occhio agli sforzi laterali sui giunti, bene le soluzioni con teste che si muovono (Powerball) ma se volete fare bene e smart mettete un grillo su ancora e un giunto qualche maglia prima dell'ancora che garantische la non torsione della catena (anche se suona come mettere il grillo direttamente tra fuso e Kong, senza maglie in mezzo), così:
Doveroso segnalare che all'inizio della pagine dedicata ai giunti dice anche:
The choice of connector (ovvero del giunto) depends on a number of things. Essentially, if you don't know you need a swivel, then you probably don't, so just use a shackle (ovvero un grillo). SmileSmileSmile
Fonti:
http://www.rocna.com/kb/Swivels
http://www.rocna.com/kb/Shackles
(Questo messaggio è stato modificato l'ultima volta il: 04-11-2010 16:03 da Madinina II.)
04-11-2010 07:28
Edolo Offline
girella dell'ancora
Devo dire che però, visto li così il kong, fa un altro effetto, ovvero è in un punto dove sforzi laterali non ce ne dovrebbero essere. In questo dovrebbe essere messo ad una distanza cicala<->kong inferiore rispetto a quella barbotin<->musone, pena salparsi l'ancora a mano per l'ultimo tratto.
04-11-2010 16:09
sarastro Offline
Registrato: Oct 2008 Online
girella dell'ancora
io non capirò mai il tirare al risparmio su ancore, giunti catene e cime d' ormeggio
speculare qualche decina o centinaia di euro mentre la barca vale da qualche decina di migliaia di euro a centinaia di migliaia
serve catena più lunga ? si compera tutta di un pezzo, possibilmente certificata
giunti ?
non ci sone che tre alternative:
wasi powerball, il meglio secocndo me, mai visto in vendita in italia, su internet per esempio:
http://www.svb.de/ankern+anlegen+tauwerk...+ball.html
azienda corretta, provata personalmente
giunto kong
http://www.kong.it/pr_yach.htm
meglio quello rotante, che toglie i giri dalla catena, provato va benissimo
se siete iperiperprudenti integrate quello da 8 mm in modo da evitare situazioni limite di trazione trasversale, quelli da da 10 mm in su sono ok
grilli calibrati, per es:
http://www.motomarine.it/scheda.asp?IDSo...PrmFiltro=
che dichiara il carico di rottura e non ha sporgenze che possano interferire con il musone
meglio ancora ad omega
però ha il perno sporgente
comunque così non si permette la rotazione di ancora e catena come fanno wasi e kong
dormite tranquilli
dimenticate tutto il resto ... grillini e grillacci non certificati, false maglie ecc.
saluti velici
sarastro
04-11-2010 17:48
Madinina II Offline
girella dell'ancora
giunti ?
giunto kong
dormite tranquilli
saluti velici
sarastro
Sarastro, credo che ti quotino tutti in questo 3D, i contenuti vanno proprio nella tua direzione...
04-11-2010 19:10
augustob Offline
girella dell'ancora
due ultime domande:
1. il grillo zincato mi sembra una buona soluzione: basso costo e massima resistenza. Giusto?
2. grillo in inox Winchard a brugola: come si blocca per evitare il rischio di svitamento?
Madinina II: trovo ottima l'idea di inserire la girella dopo qualche maglia (le idee semplici mi entusiasmano, la loro genialità è implicita).
04-11-2010 19:10
Madinina II Offline
girella dell'ancora
Citazione:augustob ha scritto:
due ultime domande:
1. si, ma sempre massima attenzione a ciò che acquisti e relativa qualità
2. il suggerimento di Edolo è intelligente, colpo di bolino sul perno latto filettatura (e magari anche collante su filetto prima di avvitare)
04-11-2010 19:12
Madinina II Offline
girella dell'ancora
Si, fa un'altro effetto e concordo sulle tue considerazioni sulle distanze...ma secondo te Edolo non sarebbe come mettere in sequenza cicala-grillo-Kong senza frapporre maglie della catena tra grillo e Kong? ...così si evitano i problemi di distante tra musone e borbotin.
(Questo messaggio è stato modificato l'ultima volta il: 04-11-2010 19:15 da Madinina II.)
04-11-2010 19:15
Edolo Offline
girella dell'ancora
Secondo me no. quel pezzettino di catena immagino serva proprio per evitare che il kong sia troppo vicino all'ancora. Infatti è quando la si salpa ed entra nel musone il momento più critico per il giunto, dove soffre le sollecitazioni laterali: una volta incanalato nel musone non può più ruotare liberamente quindi con delle sollecitazioni laterali, classiche di quando si salpa l'ancora, il giunto cede. Inoltre in quel momento la catena è bella in tensione, non regalando niente in termini di assorbimento.
Forse il grillo, come lo metteresti tu, potrebbe servire per spostare di qualche cm quel punto critico oppure per far lavorare il giunto perpendicolare rispetto all'ancora, immaginando che un grillo (o una maglia in più o in meno) fa ruotare di 90° l'attacco rispetto l'ancora.
IMHO ovviamente...
04-11-2010 19:38
sarastro Offline
girella dell'ancora
IMHO ovviamente...
scusa edolo
ma un giunto che cede sul musone, mentre si salpa, durante la manovra ... ma ti è successo ?
ma che giunto era ?
ossssigggnnuuuurrrrrr Sleepy
saluti velici
sarastro
04-11-2010 20:28
pieros Offline
girella dell'ancora
Interessante !!!
Mi piace molto questa soluzione ! Smile
04-11-2010 21:20
Edolo Offline
girella dell'ancora
ma che giunto era ?
saluti velici
sarastro
successo proprio così, come scritto quotando RMV. L'ho anche raccontato in qualche discussione.
05-11-2010 01:30
Madinina II Offline
girella dell'ancora
giunto kong
Sarastro, per capire: cosa intendi con 'integrare quello da 8', aggiungere grillo tra Kong e ancora?
Io ho catena dell'8, notavo che il Kong 644 ha un carico di rottura di 25 kN (circa 2500 kg), mentre una quasiasi catena zincata arriva a 4000 kg, come pure i grilli Wichard. E' un limite?
Sovradimensionare un Kong (es quello che va bene sia per catene da 10 che da 12 ha un carico di rottura di Kg 5000) presenta contro-indicazioni ??
(Questo messaggio è stato modificato l'ultima volta il: 05-11-2010 04:14 da Madinina II.)
05-11-2010 04:02
dapnia Offline
girella dell'ancora
Se non conoscendo l'argomento, giustamente, ci si informa in modo da sapere di cosa si sta trattando,
se si compra roba di buona marca, che abbia certificazione scritta (magari incisa sul pezzo) del carico di lavoro e del relativo carico di rottura,
se si dimensiona il tutto con criterio e conoscenza, non barando o accontentandosi di approssimazioni, ma considerando i margini di sicurezza corretti,
se si monta il tutto secondo la buona regola,
se si usano le cose secondo quello per cui sono state costruite,
se si rimane nei carichi considerati,
direi che il rischio di danni è abbastanza remoto.
Certo può sembrare di spendere di più...
Big Grin
05-11-2010 04:49
sarastro Offline
girella dell'ancora
giunto kong
- integrare: intendo evitare i rischi di rottura per trazione trasversale, il kong da 8 dichiara come scrivi 2.500 kg di carico di rottura longitudinale ma 850 kg di trasversale
quindi
prendiamo un dato da
http://www.rocna.com/press/press_0612_wm_ym_testing.pdf
secondo l' America Boat and Yacht Council per un 35 piedi - tipicamente catena da 8 - la trazione in tempesta è di 1.600 libbre, cioè 725 kg
normalmente il complesso ancora-lineadiancoraggio si posiziona longitudinalmente, cioè il giunto stra-tiene
se l' ancora sui dovesse incastrarsi in una roccia e il vento girare, il giunto potrebbe sforzare, potrebbe (potrebbe) infine arrivare ad un valore critico
se proprio vogliamo essere iperiperprudenti, con un gambetto-grillo, ed eventualmente spezzone di catena come foto sopra, si potrebbe diminuire questo rischio, però meglio se il gambetto/grillo fosse ad omega, in ogni caso deve essere a carico dichiarato, vedi sopra
- non so, non ho provato se il perno del kong da 10, che sarebbe sovradimensionato, entra nella maglia della catena da 8
- con powerball risolvi tutto, oppure due gambetti/grilli ma dovrebbero essere ad omega a carico dichiarato vedi post sopra - salvo passare per il musone e non rotazione per togliere i giri alla catena
per chi volesse divertirsiSmile
http://northpacificresearch.com/download...vealed.pdf
saluti velici
sarastro
05-11-2010 06:01
Blu Offline
girella dell'ancora
Il Kong da 10 entra, da un lato, nella catena da 8.
L'altro lato, quello più spesso, non entra su tutti i fusi: nella mia esperienza cqr da 25 (26?) libbre e Rocna da 15 kg.
Questa estate ho inizialmente rimediato interponendo un bel grillo tra fuso della Rocna e la girella Kong.
Il risultato è stato che in più di una occasione la girella si è incastrata tra gillo e fuso (con il grillo rivolto verso l'alto, impedendo un tiro corretto. Ergo, ho optato per due grilli, uno bello grosso sul fuso e uno più piccolo per necessità di diametro catena.
La soluzione dello spezzone di catena tra grillo sul fuso e il giunto Kong mi sembra una buona idea che dovrebbe permettere di avere un tiro sempre in linea.
PS sia con il giunto, sia con il solo grillo , l'ancora salpava sempre storta..... e dovevo girarla a mano.
OT nella discussione
Piccola postilla sulla ROCNa: pur non avendo mai preso venti superiori ai 20 Knts, sono veramente soddisfatto del suo comportamento. Prende in una frazione di secondo e almeno di punta agguanta sempre anche in situazioni difficili.
Ho però riscontrato una caratteristica che talvolta inizialmente mi ha dato qualche problema, poi ci ho fatto la mano. Quando alo catena mollo abitualmente il barbotino e lascio filare, ebbene, ho notato che la Rocna plana nell'acqua e finisce anche qualche metro di lato in avanti rispetto al punto precelto: il vantaggio è che la catena fila progressivamente con tensione costante, lo svantaggio è che quando sto cercando di centrare una piccola zona senza alghe in fondale alto, non sempre finisce dove voglio. Qualcuno lo ha notato ?
05-11-2010 15:14
sarastro Offline
girella dell'ancora
ho la rocna da poco, condivido le buone impressioni però finora sempre ancoraggi tranquilli, vedremo sul lungo termine
quanto al planare non saprei, perchè dovrebbe planare più di altre ancore con grande superficie, anche maggiore in proporzione vedi danforth o fortress ?
in genere io ancoro a barca ferma e non mollo di colpo ma faccio filare col verricello, qualsiasi ancora scende in verticale sul punto prescelto, poi dando retro la catena si distende
saluti velici
sarastro
05-11-2010 16:31
nour Offline
girella dell'ancora
Interessante discussione che vorrei estendere sensa aprire un nuovo thread (ma se i moderatori ritengono che sia troppo OT rispetto al titolo originale, ne apro uno immediatamente).
Quest'anno intendo rivedere la mia linea d'anconraggio che attualmente è costituita da 55 mt di catena dell'otto da un'ancora bruce e di un connettore marchiato 'force'. barca di 11.30 mt e circa 5.900 kg.
niente di tutto questo mi convince del tutto per cui vorrei una rocna da 15kg ma credo interferisca con il bompresso (devo provarla) e allora probabilmente andrei su di una Kobra2, 65 mt di catena e un giunto serio e ben dimensionato.
le domande:
1. il wasi powerball non lo conoscevo per cui ero già orientato su di un kong. se però qualcuno lo utilizza (il wasi, forse sarastro?)mi piacerebbe avere qualche commento soprattutto sull'efficacia della rotazione.
2. qualcuno usa o conosce Kobra2? sulla rocna nessun dubbio forse per davvero la miglior ancora in produzione però il bompresso lo uso e temo, salvo effettiva verifica che farò a breve, che il roll - bar della rocna interferisca.
3. ammetto totale e profonda ignoranza in tema catene, per cui vi chiedo se esistono catene che a parità di calibro e carichi di lavoro e rottura pesano meno di quelle 'normali'. poichè vorrei aumentarne la lunghezza di almeno 10 metri (ma anche più) ma vorrei però non aumentare il peso a prua.
grazie
05-11-2010 17:34
sarastro Offline
girella dell'ancora
mi sono deciso ad acquistare il powerball per carico di rottura e snodo e va benissimo, lo snodo permette la rotazione mentre si salpa togliendo i giri dalla catena e passa perfettamente sul rullo, come peraltro il kong
non saprei quanto sia davvero importante lo snodo quando l' ancora è sul fondo, lì conta di più la robustezza, credo
come scrive blu, ocio chesulla rocna da 15 il kong da 8 non va, il fuso è troppo grosso
saluti velici
sarastro
05-11-2010 17:58
Madinina II Offline
girella dell'ancora
Ti rispondo da persona che ha intenzione di cambiare l'intera linea di ancoraggio (barca First 375, kg7000, 50 mt catena dell'8, Bruce 15kg, giunto Kong); andrò su 75 mt dell'8 zincata calibrata, ancora Delta (anche io ho problema del bompresso, la Rocna non ci stà neanche a morire, la Spade è cara). Stò riflettendo su giunto/grilli, ecc.
Sarastro mi sembra molto competente in tema di attrezzatura da ancoraggio, se lui dice che il PowerBall funziona bene (e i carichi sono alti), mi fiderei. Io non conosco il prodotto.
Butta 'Kobra2 anchor' su google e qualche discussione su forum stranieri la trovi. Sembrano emergere pregi (ottima tenuta, prezzo) e difetti (lo snodo - visto che è pieghevole - tiene?). Nel test fatto è risultata la seconda dopo la Spade. Ma il test era francese e la Kobra 2 è....francese, puzza la cosa. Strano che la Kobra2 è la copia della DELTA e quest'ultima sia arrivata sesta.
Se dovessi scegliere tra le due (Kobra2 vs Delta) non avrei dubbio alcuno, DELTA (considera che si parla di Plastimo vs Lewmar...c'è partita secondo te?).
Il prezzo? Delta 16kg: € 200
grazie
Prodotti italiani, carichi certificati, calibrata, stop. Rigamonti e Maggi.
Il peso? Non deve pesare poco la catena...e poi pesa quello che deve pesare se il materiale è acciaio zincato (circa 1,4 kg al metro).
(Questo messaggio è stato modificato l'ultima volta il: 05-11-2010 19:35 da Madinina II.)
05-11-2010 19:35
nour Offline
Messaggio: #40
girella dell'ancora
[quote]
grazie della risposta.
si di sarastro mi fido Smiley14 in effetti.
per l'ancora. ho usato Delta per molti anni su le barche che avevo prima e devo dire che non ho mai avuto problemi (salvo una ma colpa mia e non fa testo). Pensavo a Kobra2 perchè ho visti i test e la valutazione era di molto superiore a Delta. Non mi riferisco a test francesi ma ad un test apparso in Yachting Monthly di novembre 2009 (se ti interessa ho l'articolo in pdf). In effetti confermavano anche loro che un aspetto critico della Kobra1 era la parte mobile ma la Kobra2 è stata modificata e c'è anche fissa. Poi tra lewmar e plastimo non so (peraltro entrambe sono costruite in cina ma non è elemento di valutazione perchè dovrebbero essere realizzate secondo degli standard imposti).
cma replicherei tranquillamente con una bella Delta ma sono molto attratto dalla Kobra2 perchè sembra funzionare meglio sulla carta .. ma non mi basta ed ecco perchè cerco qualcuno che l'abbia effettivamente usata sul campo. Poi il prezzo è relativo, in fin dei conti ci attacco la barca con tre figli sopra Wink.
Anche la Spade S80 è risultata gran ancora e ci sto riflettendo seriamente.
Grazie per le dritte sulla catena, sei per caso a conoscenza se le aziende che hai citato vendono direttamente?
05-11-2010 20:37
  Polmone dell' autoclave , perde pressione FIL 11 975 05-01-2024 18:01
  Riscaldare serbatoio dell’acqua cacao 9 1.079 10-04-2023 20:38
  Gavone dell'ancora che NON è un gavone dell'ancora. Benzaiten 16 1.682 16-08-2022 21:46
  ancora Vulcan-Spade [impressioni su ancora Vulcan] enio.rossi 27 7.841 24-06-2022 23:01
  Zerbinati e misura dell'umidità Mike 3 974 15-05-2022 09:25
  Pannello antiscivolo, stato dell'arte angelo2 2 929 26-09-2021 12:02
  catena dell'ancora attorcigliata andante 30 3.998 25-08-2021 23:14
  Corrosione catena ancora (ancora inox) [ancora/giunti/catena di materiali diversi] stravento96 29 4.425 24-08-2021 08:57
  'piedino' dell'asse che balla ---come è fissato? andri2bajo 34 6.777 12-08-2021 09:24
  Pitturare il gavone dell’ancora FrancisDrake 5 1.231 01-06-2021 14:31
